Need help on Run Server Side Script in ATF
Khalid9030
Hello Team,
Our requirement is to display the field value of a related list record using the 'Run Server Side' step. The provided code executes successfully during testing, but the output message is not displaying as expected, as shown in the attached file. Please assist me.
Note : Same logic i have tested in background script with record sys id its working as expected
(function(outputs, steps, params, stepResult, assertEqual) {
    // add test script here
var mmRecordSysID = steps('3a66daa9c3e21a50773116977a01314b').record_id; // Submit form step sys_id taken
var mmgr = new GlideRecord('x_fu_mast_main_request');
mmgr.addQuery('sys_id',mmRecordSysID);
mmgr.addQuery('status','completed');
mmgr.query();
if(mmgr.next()) {
var grLog = new GlideRecord('x_fu_np_lv_import_log');
grLog.addQuery('request_number',mmRecordSysID);
grLog.addQuery('level','info');
grLog.query();
if(grLog.next()){
outputs.table = 'x_fu_np_lv_import_log';
outputs.record_id = grLog.message;
stepResult.setOutputMessage("The import Log Message is" +grLog.message);
stepResult.setOutputMessage("Successfully Log generated");
        stepResult.setSuccess();
return true;
else{
stepResult.setOutputMessage("Failed to find message");
stepResult.setFailed();
return false;
Ankur Bawiskar
@Khalid9030
did you create the correct output variable of that server side script step?
Ankur Bawiskar
@Khalid9030
@Khalid9030
