Auto create a problem if Major incident is resolved
sattar3
Hello Everybody,
The requirement is when a Major incident is resolved then automatically a Problem ticket.
I created a BR to implement this but it is working sometime and sometimes not working.
Please check the below script and let me know if any changes needed.
I installed the Major Incident Management Plugin also.
One more thing is do i need to use Major Incident Management application scope or Global scope also fine?
BR Script: After Update
    // Short Description, Problem Manager Assignment Group, and Responsible IT Organization to populate with the corresponding information from the Incident Record.
    var problemGR = new GlideRecord('problem');
        problemGR.initialize();
        problemGR.short_description = "RCA for Major Incident " + current.number;
        problemGR.description=current.close_notes;
        problemGR.assignment_group=current.assignment_group;
        problemGR.cmdb_ci=current.cmdb_ci;
        problemGR.insert();
        current.setValue('problem_id', problemGR.number);
        gs.addInfoMessage("Problem " + problemGR.number + " created from this Major Incident.");
})(current, previous);
Sattar
Ankur Bawiskar
@sattar3
it already happens if you resolve P1 or P2 INC
Problem is OOTB created when a major INC is Resolved.
I shared the details few months ago how and from where it's created.
You can tweak the OOTB Flow Action "Create Problem Record from Incident" and the Script Step to add/remove the new fields.
sharing the link where I responded earlier
Automatic problem record is getting created when M1/M2 incident getting resolved
💡 If my response helped, please mark it as correct and close the thread 🔒— this helps future readers find the solution faster! 🙏
Ankur Bawiskar
@sattar3
if you are still using that custom BR then update this line
I hope your BR condition is proper
current.setValue('problem_id', problemGR.sys_id); // you should set sysId here and not number
Hi @Ankur Bawiskar thanks for your quick response.
It might be beacuse of relying on problemGR.sys_id immediately after insert() can be unreliable in some contexts.
I used below script which works:
    problemGR.short_description = 'RCA for Major Incident ' + current.number;
    problemGR.description = current.close_notes;
    problemGR.assignment_group = current.assignment_group;
    problemGR.cmdb_ci = current.cmdb_ci;
    var probSysId = problemGR.insert();
    // setting problem id
    if (inc.get(current.sys_id)) {
        inc.problem_id = probSysId;
        inc.update(); // required in AFTER
    gs.addInfoMessage('Problem ' + problemGR.number + ' created from this Major Incident.');
Sattar
@sattar3
sysId should be available immediately after insert()
that should not be an issue.
